Where to buy OEM oil dipstick for 4.2 258
CJB4POWERBILL
- Shelby,NC
- 1983 CJ7 258 4.2 I6 - T5/300 - Dana 30 Front - AMC 20 Rear - motorcraft 2100 carb, nuttered factory dist, all smog emisions removed, Bridgestone Desert Dualer 31-10.50-15 tires, Upgraded Heater Blower to the Blazer 103, Sunpro RPM gauge, Sunpro mechanical oil gauge, new main bearings, main rod bearings, oil pump, RMS, distributor gasket, oil pan gasket,
Where can I find a factory or factory like oil dipstick . I dont need the tube or the kits that they are selling with a new tube and dipstick( which is different than OEM length). My dipstick tube is fine. I just want the factory dipstick itself? New or used idk. PO of my jeep cut off stick that is not a jeep stick and there are no add or full marks on it. And yes I can completely drain oil and put on new filter and new oil and mark this stick i got , but there is so much contradiction as to 5, 5.5 or 6 quarts oil needed in a 1983 stock AMC 258 i6 / 4.2l AMC 258 i6 / 4.2l
, I dont know what the right answer is. Cause I dont want to be a quart over or a quart under. would rather just have the right dipstick in it.
