Which parts I need for Injection swap too?
Chriss
South Germany
1983 CJ7, AMC 360, T176, DANA 300, Axles Stock with true trac, 33" Cooper STT tires, 4" lift by Trailmaster
1999 JEEP Grand Cherokee 4,7 stock. Family car
I have a 360 AMC V8 with a carb. Overzized 6.0 liter and a Edelbrock cam. Now I want to do a Holley Pro Jection 2 Marine swap. It´s ne/used but never build in the car but a complete kit with fuel pump, harness...
Which parts more should I buy?
Is the stock motorcraft distributor enough or must it be a H.E.I ?
What is with the manifold? My carb is a 4 bbl Holley but I think it is a 2bbl TBI.
I need a little bit help..:rolleyes:
O.k. I found and read a lot of the Holley injection systems. Now I should know, which system is good enough for the AMC 360.
I found a Holley Commander 950 Pro TBI but I think it`s too big for the engine? It´s a 4 barrel TBI cause I mean 2 barrel are enough. What do you think?
The second system I found is the Holley Pro Jection II Marine. It´s a 2 barrel 670 cfm TBI.
Now my meaning is that the second system is right for my AMC engine....
I think as long as you are around 670 cfm it will work for both the four barrel or the two barrel. I run a 670 cfm two barrel Howell TBI on an AMC 401, so I think you will be ok either way.
Thank you. That was my hope! Are there more things to do like a new distributor? I have the stock Motorcraft distrib. The manifold is also the same? It´s a Edelbrock Torker for 4 barrel carb.
I know many questions but I´ll do it right for a lot of bucks...
Fill in your profile so there is more information to help you. I changed out all my electrcai system to MSD before I did the TBI. Control module, rev limiter, coil, distributor, plug wires. I was having issues with the stock electronic control module and the coil and wires. So I changed it all out. If the electrical system is good you might not have to do any thing.
