which shock mount???
reptile610
- st. clair shores, MI
- 1982 CJ7: 151cu iron duke/ sr-4 trans/ dana 300/ dana 30 front amc 20 rear 3.73 gears.
so i swapped from narrow track axles to wide track axles. i did installed the higher upper shock mount on the front but now i'm left with this? do i install the shocks into the mount on the frame or do i cut off that mount and install them on the leaf spring plate??? they're stock shocks on a jeep with no lift
