which size tires
yleefox
I'm at the point where I need new tires. I currently have 31x10.5x15 ATs on my 83 CJ7 and they were fine when we lived in Central Florida and did nothing more than ride around in the woods, on flat logging roads with no rocks, just a little sand and mud at times.
Now I live in south Alabama where most of our trips will be similar to what I described above, however we will finally be close enough to take it to the southern Appalachian mountains, where we will most likely find more difficult trails. We are not going to be taking the tough trails, but I would like it to be able to handle the more moderate trails. I expect mud, sand, slippery clay, washouts and small rocks.
If I stick to the 31 sized tires, all I need to do is buy them, but if I go with 33x12.5 I will need to replace my wheels (wider), and install a 4 inch lift (BDS most likely).
I have 3.54 geared Dana 30 and AMC20 axles. I also have a T-18 , granny low first gear and a fresh AMC 304 with plenty of HP.
So, with all of this being said, should the 33s give me a substantial performance boost over the 31s? I'm planning on Mud tires this time instead of the ATs. This Jeep will see very little street use, mostly just getting us back and forth to the National Forest just a few miles away.
So what do you all think?
