Wierd spark plug device...
I was pulling the plugs out an '83 CJ7 (AMC 258 i6 / 4.2l -4 spd) and the plugs in the back two cylinders had the device in the picture attached to them. I googled them and they were listed as either adapters for using plugs that would not have otherwise fit the thread pattern or "anti-foulers". You can't see from the pics but the firing end is sealed up with just a small holed drilled in it. I guess the idea is that it keeps excess oil off the plug tip. Anyone ever seen these used before?
Chris
Austin TX
'83 CJ7 AMC 258 i6 / 4.2l -4 spd
Chris
Austin TX
