Will it fit
Will it fit
Wreck
Clarksburg Pa.
84 CJ7 AMC 151 Iron duke T5 tranny 300 transfer case No diffs
Ha just found a scout 80 frame with posy axels I can't spell but I was woundering if they would fit under my CJ7 ? thanks!
Yes, they will fit with a little work. The axles are slightly wider then a CJ widetrack...about 2 inches if I remember correctly. Spring perches need to be relocated and the front outboarded. The Scout front axle comes factory with 0 castor. Highly recommended you cut and reweld the knuckles to gain castor.
Thanks for the input but for the work I think I will have to pass on the rears. I thought if it was just a mater of boulting them in it would be a good idea but I dont wount it go wider I'm not a rock crouler.
$100.00
  50.0%
