i have a 74 CJ5 with a AMC 304 in it and the el manuel arm strong isnt going to cut it. can i take the pump and steering box off of a wagoner will bolt up. can yall give me yalls advice (sorry for the "yalls" im from texas cant help it).
Same trouble in MS, LA....... English teachers falling down on the job!
"Y'all" is singular. The plural is "All Y'all".
My '80 CJ7AMC 304 and pwr steering uses AGR Superbox II and Super Pump, with a spring-telescoping steering shaft from Flaming River. Smooth as glass. PS pump mounting should be your biggest worry.
I'm pretty sure the motor that's in there right now came from a newer rig cause it has studs and the "random bolts" where it should go. And I always have a welder and a tourch. Oh and not to mention the main reason I think the motor had on to begin with is the fact I do have a 2 belt fan and crank pulley.
