will this power steering pump fit
FiNorman
Lifetime Supporter
Orlando, FL
1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
I was curious about the ps pump. I have read that it is the saginaw pump, sometimes described as the ham can pump. Will pumps from other GM vehicles fit it? I found a pump that I liked in chrome, from a company called March performance. I called them to see if it would fit and they described it as the saginaw AMC 304 . Accesories Power Steering Pumps, Alternators. They also describe a keyway style and a press fit style.
If it matters I am changing the pulley system over to a bulltear serpentine system.
The big difference with the two styles is the fitting are metric on the newer pumps.
Not sure what pulley the serpentine use. V belt used press fit which can also help line up the pulleys.
