Will This Sway Bar Work With This Jeep and What Other Components Will I Need?
Papapegasus
- Media
- 3
- Dallas, NC
- 78 CJ7, 360 Mopar, TCI 3 Speed Auto, Dana 30 Front, Dana Tranfer, AMC 20 Rear
Got a few questions for you guys. First, I bought this Jeep about 2 months ago. The front end is all over the place, worse at speeds over 45-50 mph. Took is by a 4x4 lift shop here in Charlotte and they said first things first that there is no sway bar, and that would help a lot.
Would this one work, and if so, would I need any other components? There are already holes on the frame for one as well as the bolts/mounting location down by the axle.
1978 JEEP CJ7 Addco Performance Anti-Sway Bar Kits 712 - SummitRacing.com
They also pointed out that the bushings on the springs are badly worn out and need replaced, and that the axle looks like it is shifted over about 1/8 inch from all the bouncing around this thing does on the road.
I already replaced the tie rod ends and drag link end and had the alignment done, for all that's worth about a month ago.
Also the steering damper is leaking slightyly (just moist on the arm). I am assuming that is blown, would replacing that help?
Thanks for your help. If any additional pics would help let me know.
