Winch cable ?s
Where do you get your winch cable at? Should I go synthetic considering I need to replace my linked/frayed one?
Due to my age, I would recommend synthetic, since I am not fast enough to dodge a broken cable. This is an article that Four Wheeler mag did:Steel Winch Cable Vs. Synthetic Rope - Four Wheeler Magazine
The only downside I see to synthetic's are the price and they only last a few years if exposed to weather.
I'm a fan of old school steel cable, hard to beat over 100 years of success. If I'm making a long/hard pull I tie a jacket (or whatever else you have in the cab) on the line to help absorb some of the energy in the event of a break.
Still using the same steel cable on my Warn 8274, that it came with in 1977.
This is a debate I've turned over in my head. One reason to go with synthetic is the fact that for any given strength the cable is smaller in diameter. Which means that you can spool more cable on the winch. Naturally cost is a negative, but the biggest negative for me is the climate I live in. The summer sun is brutal and the sand/dust is ever present. Steel, while shorter, really doesn't give a darn about the sun and sand with the dry climate making rust mostly a moot point. But, synthetic rope is very cool to have on your winch. Honestly, if I were to be heading out for a long summer 4 rough wheeling trip I'd have synthetic rope wound on the winch, until then I'm perfectly happy with the relatively un-used cable the winch came with knowing that it will always be there in good health ready for use.
If I needed a new cable I would want to try the synthetic. just because of the lack of splinters and ease of handling. The synthetic comes with a replicable UV resistant cover for the first few feet, enough to make one layer on the spool. Letting the cable slide in my hand when rewinding and not cringing at the thought is interesting. I love the winch and would not be without it but truth be told I really don't use it that much.![]()
