wiper motor
wiper motor
kenpoman2003
Whitefield, Me
1986 cj7 4" suspension lift, 2" body left. am going to install rear bumper tire carrier, front bumper brush and grill guard, front roll cage and tie in kits. all as money becomes available. dana 30 front end with quadraqtrac four wheel differential. amc 20 locking differentail in the rear. Have solid piece axels just waiting to be installed some slow winters day hopefully in heated garage. Am also going to do, do it yourself paint in tub liner havent decided which one to go with. Any sugestions? hope to do this to the underbody and frame as money allows. I have ordered marine interrior lights for under dash and bach passenger compartment and under hood w/ heavy duty toggle switches. I plan to install a secondary fuse block to acommidate any accessories I may someday get. I know it sounds like a lot but its a pick away project with no deadline. and as money provides.
dose the wiper moter conect directlyto the switch and can it be changed withot takeing the windshield down? Is there a diagram available?
thanks Jon
You need to remove the padded dash. Then replacing the motor is easy. There is a clip that attaches the linkage to the motor. The motor doesn't move very far until you remove that linkage. If you have a hard time removing it then take off the plastic access cover at the driver's wiper pivot. There it will be easier to remove the linkage that goes to the motor. Then the motor will come out with this linkage.
Also that connection on the motor does end up going directly to the wiper switch on the dash.
you do need to drop the windshield to get the padded dash off. it has screws that hold it under inbetween the tub and windshield frame.
And if I remember right the wires go thru the top of the tub under the w/s frame.
$35.00
  17.5%
