Wont shift in to reverse
I have discovered a new issue with the 85 CJ7 .
It wont shift into reverse while the jeep is running. If i try it just grinds the hell out of the gears. So i had to switch the engine off, then shift into reverse, then turn the engine back on. I looked through the troubleshooting section of the haynes manual and didnt see anything. The only thing i can think of is clutch linkage adjustment maybe. ANy other ideas? Its fine in all the other gears. Thanks.
