    Thank you for your support!
Wynns Automotive Softtop
Formula 40PC
Kirkwood
'76 CJ7, 360, TH400, Quadratrac
Does anyone know where I can get door handles for old new stock Wynns Automotive soft doors?
I picked up this brand new fastback top(actual age unknown but never been installed) but the doors have no hardware.
Any ideas of where to start?
Wow I don't I have ever heard of wynn tops, you think a best top handle will work?
Wynn Automotive and Kayline used to be 2 pretty big suppliers of Jeep, Scout and Bronco soft tops back in the 60s-80s. I am hoping the bestop handle will work, it's got the same part # as the old Wynn. I just had hopes that someone way have a little more knowledge on the old tops and manufacturers. I bought the top because it is a fastback that requires no frame, just goes from the windshield to the rollbar and down to the tub rail. Very rare by the looks of it. Hell, I way never even need the doors but would like to know I have the hardware. The other thing I need is the door hinge with the post that mounts on the door.
Wynns is not a name I've heard before as a soft top supplier to AMC. :confused:
My OEM soft top was made by Witco.
Is that the same as White Top Company (whitco) Denver, Co. ?
Nor sure if it is the same as Whitco. Wynn Automotive is also in Colorado. I have attached the original paperwork.
Do you mean White Automotive Corp Colorado Springs?
I believe Whitco/White were/was the same.
Kayline is from Denver as well.
Post pictures of the bows and door handles.
