XJ steering column in a CJ
cjbilly
- East Central Indiana
- 1984 CJ 7 with rebuilt AMC 360/ 2 bbl. with Turbo 400 and Dana 20 transfer case (twin sticked). Dual red-top Optima's. Lokar shifter with rebuilt/modified tranny. Dual Flowmasters out the back.
1985 Dana 30 and 1986 CJ Dana 44 with 3.73's. Steering box brace. Central axle, tranny and transfer case breather box. Detroit locker (rear) and ARB (front). 35x 12.50-15 MT/R's on 15 x10 ION alum. simulated beadlocks.
How many people are looking for a tilt steering column for there CJ? I know, the CJ manual columns are hard to come by and can be $$$ or need to be rebuilt.
As an alternative, I installed an early ('91) XJ column in my CJ with great results. Having a floor mounted shifter for my automatic made it easy because I did not want to deal with a column shifter. Most XJ's have center console shifters anyways.
1. The CJ wiring harness/plug that plugs into the base of the shaft works, nothing to worrry about.
2. What you need from the JY is the XJ intermediate shaft that goes between the end of column and steering box.
3. I heated up my CJ intermediate shaft to melt the plastic where the two shafts meet.
4. Do the same to the XJ shaft.
5. You will need to use the lower shaft for connection to the CJ steering box and the upper shaft on the XJ steering column. The two shaft ends should slide into each other. I added never seez on the smaller rod.
The XJ steering column has both bright lights and wiper features on them. If you are good at wiring, you can incorporate those features into the XJ column. At this time, I do have the bright lights working off of the column. I tried hooking up my intermediate CJ wiper control on the column but ran out of patience.
Hope this helps.
Hope this helps.
