YJ tub on CJ frame, what is this metal frame
FiNorman
Lifetime Supporter
Orlando, FL
1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
Testing our YJ tub onto the CJ frame... it looks like it fits fairly well, but I ran into a problem.
On the driver's side mount, by the foot pedal, adjacent to the fire wall, the bracket for the frame mount is not only horizontal, but has a portion which is vertical... off of this vertical portion is a 1/4 to 3/8ths inch piece that sits at 90 degrees and consequently won't allow the tub to sit flush against the vertical piece.
Does anyone else have this? should I Just cut this piece down?
anyone know the dimensions to have the frame connector in front of the rear wheel in the right position?
Cut the piece down or off. It's not stock. It's something that someone welded on there for some reason.
I agree, the piece does not appear structural from your pictures, so, use the smoke wrench and your problems will be solved.
So cut it off the 3/8th piece that runs parallel to the frame and perpendicular to the firewall, or cut the larger piece that runs parallel to the firewall and perpendicular to the frame rail and prevents the tub from sliding forward?
I see the mount should be flat... thank you.
Hi I recently found a YJ tub for my CJ7 and was wondering how your swap is working out. Could you post more pics as you go through the swap?
Hey! How is this swap coming along? Please share your experience. And preferably with pics. :D
Please be darned careful using a torch next to on fiberglass. Can you say BURN baby BURN.
