1960 cj-3b rolling difficulties
mrwocohose
PACIFIC SOUTH WEST
Hello all Cj'ers,
I'm currently looking to cure a rolling issue with a 60 CJ3b . It's a converted willys into a fire truck. There is weight involved but is difficult even with a forklift pushing it. Its been sitting and out of service for years, however it recently has had a complete new brake system and tires installed. New shoes, cylinders, master, lines ect. The brakes are not the problem.
Any suggestions ??????
Many Thanks !!!!!
P'brake not releasing.
Put tranny and t'case in "N".
did you put it in neutral or just put in the clutch? if you just put in the clutch then try putting it in neutral the clutch might be sticking. i would jack it up and start eliminating possibilities try putting the clutch in have someone try to spin the wheels then put the Transmission in neutral try again then put the tcase in neutral and try then try disconnecting the drive shafts. don't forget to try both the front and rear axles.
