    Thank you for your support!
1973 304v8
1973 304v8
Fort Myers, Fl
1973 CJ5
Can someone share with me the double secret method of installing a new dip stick tube into the block casing. The curvature of the tube does not seem to like going all the way into the very straight block opening.
This is on a 304V8 in a CJ5
Assisted is appreciated.
Ric
