    Thank you for your support!
1973 CJ5 width
1973 CJ5 width
gotaluvaCJ
Hickman Kentucky
1973 CJ5,304V8,33's Interco TSL, Skyjacker Softride Hydro Shocks,Wetlands Camo.
1994 Wrangler 4cyc,winch, 32's BFG Mud tires
2008 Dodge Nitro
I am having to haul my CJ from an area i rode yesterday and borrowed a trailer with side rails. The tires are flush with the stock flairs. I need to know how wide the CJ5 is from the outer edge of the tire to the outer edge of the other tire to see if it will fit on the trailer i borrowed. The trailser was bought to haul a small Kubota tractor
I don't have the measurements handy, But I haul my '74 CJ with 35" Swampers on my utility trailer ( the most common style with side rails ) all the time...
Here is a pretty stock parts Jeep came home...Its a CJ7 , but you can get an idea...
Thanks it worked out great.
:patriot:
