To celebrate the 4th of July, starting today (07/01/2025) all User Upgrades will be reduced by 10% (thru 07/08/2025) To use this special coupon use the code 2025-4th-10percent at check out. If you are already a supporter your existing package will be extended. Thank you for your support!
I actually repaired a torn diaphragm once in a Quadrajet. Used RTV and didnt expect it to go long. Temporary fix, but it held.
EDIT: I dont recommend this..^...RTV will find its way throughout the carb.
The pump diaphragm is easy to get to after you remove the top section, at least it was on the Qjet. I dont expect it's much different on the Carter
