Build Thread 1979 CJ7 Rapid restore - 1 Year build from tired and rusty to all go and some show..
Note on a comment I made above regarding the Holley jet tool and needing one if you are trying to re-jet while the carb is installed.. I did not realize that the throttle plate just pops off and the gasket is reusable so if you are re-jetting while the carb is instaled you can just take the bowl off then pop the throttle plate then swap them on the bench, as I mentioned its been 20years since I touched a carb! I have been taking off my carb becuase I cannot seem to gracefully drain the fuel without making a mess in the engine bay and its only a few mins to remove the whole thing then drain it away from the engine.
The new style re-usable gaskets these days are pretty good but they do seem to wear out after about 6 jet changes, at least one of mine did. for the price of these a good idea to have a spare set on the shelf.
Really nice work
Omix is a toss up, some is good, rest is :dung:, will be interesting to see how the gauge holds up
I agree, I bought a Omix bellcrank kit.. push rod for the clutch fork was junk, adjusted it once as short as possible, still 2 inches too long then the cheap steel threading stripped on the way out and it wont move anymore so its in the scrap pile... I will definately post up some comments on the speedo quality.
Got he new speedo and new cable installed, works but it is still really bouncey under 50mph, I have not swapped my gear yet so we will see if that cleans it up at all. One complaint on the guage is turn signal indicators are not green, kind of yellowish white, not super easy to see in the sunlight, luckily for me the turn signal auto-off feature still works so I hopefully wont be the old guy with his blinker on for 10 miles! By the waythe rugged ridge box does have the Omix logo on it, missed it when I looked at it initially and commented above that there was nothing that indicated it was an Omix made Guage.
On the fuel gauge front.. I discovered my sending unit signal is not my only issue in the system. Out for a drive on the weekend and found out my fuel pickup tube is only reaching the top 5 gallons of the tank.. since my guage problems havent been resolved yet I have been keeping a close eye on the tank and just keeping it topped up after every short trip so I never let the level drop this low yet! Luckily I wasnt far from home so the call of shame to my wife with the request for a jerry can wasnt too bad!
Fuel tank drop in progress this week, pictures of problem to follow once I get it out and take a look at what is going on with this Crown sending unit and pickup tube.. May also tackle the speedo gear and a slight leak in the T-18 inspection cover..
Might consider cutting an access into the tub for the sender...not uncommon for those to routinely take a dump based on their origin of manufacture
A lot of guys have gone with marine style hatch type panels with covers...I just used a piece of plate with four self-tappers on the corners
Definately considering this, my tank is not bad since its all newly installed but its still a 3-4 hr job for me to drop it and put it back, a panel would cut that down by a lot!!
After pulling the tank again I found the problem seeems to be a couple things.Firsty this pickup filter came off and the sending unit appears to have twisted on me a little when I put it all toghether and the float appears to have been catching the side of the tank slightly. I marked it this time so there was no confusion which way my float was pointing when I tightened it down!!
Also the Mopar Jeep branded fuel guage I bought is backwards, it works off the reverse resitance range - 0 empty and full is 70 with no way to switch that without reversing the sending units potentiometer orientation which I am sure is possible if you have the patience or in my case that one is on its way back and I am now for something that can be calibrated to the specific range of your sending unit, the Holley EFI full sweep is nice, a bit pricey.
$100.00
  50.0%
