1980, what axles?
1980, what axles?
gliryan
Duluth, MN
'70 Postal DJ/CJ
'80 CJ5 Laredo w/ 304
'76 BMW 2002
narrow trac Dana 30 front, and AMC20 rear although cant tell you for sure on the rear without a pic of the diff cover, if its round then it is for sure a amc20 rear. they will be fine with 31s, with 35 you'll want to take it easy but they can survive, the rear will definately need to have a one piece axle kit put in it.
Where would one buy a 1 piece axle kit? And a lunchbox locker for the rear?
Try Morris 4x4 or 4 wheel drive hardware.
thanks a ton for the replys and the help. I've been searching, but it seems like this "general" knowledge is hard to come by since its just a known thing. How do I know if its a wide track? That axle kit says its for an '83+, mine is an '80... I'll assume mine is the narrow track for now and until I can measure.
I'll probably get to look at it and work on it this weekend, or friday maybe, well hopefully.
here's some reading for you, it'll tell you everything you need to know about the amc model 20 axle Jeep Axle: AMC 20 there's also a link to info about the Dana 30 front as well. check the pic busa gave you and make sure you thats what you have.
$20.00
  10.0%
