Build Thread 1983 CJ7 Build Project
timemachine
Rhode island
none
Nice looking Jeep. If the top has never been off, the interior stayed dry probably. If the top has been off some, you might eventually take the roll bar off. AMC left the metal under and between roll bar unprotected and not painted. Rust on these Jeep can start inside and work its way out. Great looking specimen.
Great starting point for your build. Very, very fortunate to have no rust.
Nice progress.
Might want to check the ring and pinion ratio and see if it's still stock. A lot of CJs of that vintage came with really high 2.73:1 ratio. If going with 33" tires, you might consider a lower ratio, like 4.11 or so. With what looks like a 5-speed, it'll still be fine on the road.
Not sure if you've considered a new lower steering shaft yet. There are a couple different options out there, but a collapsible shaft with u-joints on both ends is a good upgrade and can eliminate some looseness in the system.
I ordered new differential gaskets today and plan on opening them up and inspecting, and fresh oil. Not sure how to tell which one I have but it’s the AMC20 real and Dana 30 upfront.
Please send recommendations on steering shaft so I can research.
For R&P ratio determination:
-When you have the diff covers off, count the ring gear teeth and the pinion gear teeth. The ratio is those numbers divided by each other (41/15, for example, is 2.73:1).
-Or, while the rear end is jacked up off the ground, spin the yoke and count the rotations the yoke/driveshaft makes for one axle/tire rotation. Then, multiply that number x2.
For lower steering shaft, look at Borgeson
Or
Flaming River (Link)-> FR1519-PTLT - 1972-86 JEEP CJ5 / CJ6 / CJ7 / CJ8 Slip Shaft Kit - Fits 1" DD Column w/Power Box -<
Looks good. Nice work.
Is the 2.73 a typo (even though it's a standard ratio)? I hope you mean 3.73 or your going to be just chugging along.
Nice. Good progress, indeed.
Groovy 😎
Rear axle is in, shocks, springs, brake lines, and drive shaft connected. Ordered shims for front so that will be a couple days.
Hoping to start engine this week.
