Misc. 1984 CJ7 Running Rich
Jdunn1375
205 east creek road
1984 CJ7, AMC 258, 5 spd manual
Hi. I have a 1984 a CJ7 with a AMC 258 i6 / 4.2l . I’m having an issue with a rough idle, a miss, and it’s running rich. It failed smog in California. I have replaced all basic tune up parts, coil, ICM, and a carb I bought from Amazon. It will run fine (slight miss) when it’s cold. As soon as the engine warms, it will have a rough idle and will die. Side note is that my temp and fuel gauge stopped working. Not sure of that has something to do with the issues thanks any ideas?
Maybe the mods will move this into another category where it may get better attention.
What was wrong with the old carburetor? Does the new one have the same size jets in it? Also, did you adjust it correctly or just wing it? If I'm not mistaken, the servo motor in the side of it should always be adjusting the mixture. I believe there is a requirement to disable that to tune the carb? I would not expect a new carb from Amazon to be plug-and-play.
Edit: temp and fuel gauge not likely to be related.
Could be the initial choke pull-off adjustment.
Check out this video:
Carter 2BBD - Initial Choke Pull-off Adjustment
At cold start, mine was belching black smoke, stumbling, and smelled like gas. It would settle after awhile, but would repeat the above with every start. After setting the initial choke pull-off adjustment with a vacuum pump and a vacuum gauge, it resolved the problem.
Oh... Good call... Honestly, carburetors are not my thing. I put a Howell kit on my California Jeep and have never looked back.
$190.00
  95.0%
