2.5" Old Man Emu Lift Kit...Light, Medium, or Heavy Load??
- Media
- 186
- Resources
- 1
- Plumas Lake, CA, USA
- 1974 CJ5 ~ Fresh built AMC 360 - SM420 - D20 - D30F with upgraded 30 spline shafts and knuckles & D44R - 4.27 Gears - ARB Lockers F/R - All chrome molly axles - on 33's - YJ 4" Lift Spring Conversion
here's a pic of the front with their kit installed - you can figure if your winch plate will work, mine was all custom so worked fine (built into the bumper... )
gets a little tight under the bumper: we had to notch the new bracket / mount to get it to fit tighter...
The shock mounts they sent were too long for the shocks. Had to cut and reweld the mounts. took around 4" out of them. The shocks themselves were ok.
Brake line extensions didn't work for me, ended up getting a new set of one piece braided steel instead.
just be prepared for grinding, cutting, and drilling and pay attention to the instructions and spring orientation. If you have any problems, I'll PM you my email address and phone number too in case you need it. I just went through it all.
Every jeep is different, yours may go together without a hitch
~ Jr
~ Jr
