Engine 258 1 bbl to 2 bbl conversion
bcstringer
Donator
S Clementine Street, Oceanside, CA 92054, USA
'72 CJ5, 4.2L 258, EFI, 2 bbl, Comp Cam, Headers, Flowmaster Super 44, T-18, D20, D44, D30
Howdy Jeep-CJ Community,
I've been reading your posts for years via various google searches, but now that my Jeep re-build has started, I'm running into some issues only you experienced CJers can likely help with. My 1972 Jeep CJ5 (v1.0) was my grandfather's and he taught me how to drive it well before I hit puberty. After he passed, my Dad got it and he and I restored it in 1993-94 as project v2.0 for me to drive as my first vehicle in high school. It's been sitting under my parents' house for nearly 30 years and even got completely flooded by Lake Travis in TX.
I just can't let this heirloom die, so almost 30 years later I'm bringing it back to life with project v3.0. I'm replacing the frozen AMC 232 i6 with a stroked AMC 258 i6 / 4.2l and the T-14 with a T-18 . I'm upgrading to a 2 bbl Holley Sniper EFI so need to upgrade the stock 1 bbl intake to a 2 bbl intake. I can't find any late '70s model 2 bbl cast iron intakes out there that will marry up with the stock exhaust manifold so I'm going to use an early '80s model 2 bbl aluminum intake with a detached header.
1) I will block off the EGR with a plate, but what do you do with the vacuum ports and water jacket?
2) Has anyone out there with a '70s 1 bbl intake done this conversion to an early to mid '80s 2 bbl intake before that can walk me thru a clear step-by-step?
3) Are there threads or plugs out there that I can purchase to make this easy?
Thanks in advance for any help! Glad to be here with you all in the CJ Matrix.
Thanks,
Cody
Solution
I just can't let this heirloom die, so almost 30 years later I'm bringing it back to life with project v3.0. I'm replacing the frozen 232 with a stroked 258 and the...
I just can't let this heirloom die, so almost 30 years later I'm bringing it back to life with project v3.0. I'm replacing the frozen 232 with a stroked 258 and the T-14 with a T-18. I'm upgrading to a 2 bbl Holley Sniper EFI so need to upgrade the stock 1 bbl intake to a 2 bbl intake. I can't find any late '70s model 2 bbl cast iron intakes out there that will marry up with the stock exhaust manifold so I'm going to use an early '80s model 2 bbl aluminum intake with a detached header.
Thanks,
Cody
:welcome:
Glad to have you here and I'm happy we have helped you before.
Here are some thoughts but we have others who have more I6 knowledge than myself.
  1. You can plug the unused vacuum ports. The water ports on the intake help reduce fuel puddling in the intake.
  2. I've not done one but others have. Here is a start -->> https://jeep-cj.com/community/threads/77-258-4-2-intake-manifold-conversion.7385/ *** -->> https://jeep-cj.com/community/threads/1-barrel-to-2-barrel-4-2-conversion.25305/ **** -->> https://jeep-cj.com/community/threads/manifold-swap-258-i6.59633/ *** --->> https://jeep-cj.com/community/threads/258-4-0-head-swap-results.8500/
  3. Not sure what you mean.
:welcome:
Thanks CJ! I'll take a look into those threads. #3 I guess I'll just try to find some threaded plugs that will fit. Cheers
I also contacted @elwood blues about this. He said when he gets home he will dig up what info he has saved.
Lol, if your in still in Texas you dont really need the water port, its for cold weather up north if you dont want to plumb it, i never had a problem with mine not having it
Definitely share lots of pictures we love Jeep porn
Solution
Man thats a sweet looking Jeep, i look forward to seeing it come together
Thanks I try
OP, just be happy you don't have to pass Ca. SMOG!
Ya from what I understand the sniper EFI is not ca smog legal yet
Sry I'm late to the party work has been kicking my butt. I'm running a 258 with the 2 barrel sniper. I actually use the water ports on the intake for the EFI coolant sensor. You will need a one to two barrel adapter and the throttle cable from a V8 Jeep I would also recommend a GM HEI distributor if you go headers just make sure you install the 02 sensor 4-6" past the collector and have zero exhaust leaks
Thanks @Manic Mechanic for the info and pics! I'll look into using the water ports on the intake for the EFI coolant sensor instead of another area. The used but good condition '81-'86 aluminum intake part #EF3237858 I bought has 2 barrels so should marry up to the 2-barrel Holley Sniper EFI now instead of using a 2bbl-to-1bbl adapter. I bought the Holley Hyperspark distributor and Hedman 6-into-1 HTC Headers part #99616. I'll make sure to install the O2 sensor 6" past the collector per your and Holley's recommendations.
Why a throttle cable from a V8 Jeep in particular? Will existing not work?
Here's some updated pics of build so far in order:
1. New stroked AMC 258 i6 / 4.2l engine painted '69-'73 AMC Blue Metallic Ditzler PPG #13730 (original AMC 232 i6 engine completely seized up. The Jeep was flooded by Lake Travis and water was in EVERYTHING: engine, oil pan, Transmission , Transfer Case , axles, gas tank, etc. Since no power steering and no power brakes, I stayed with an I6 in lieu of going with a V8. The stroked AMC 258 i6 / 4.2l with Holley Sniper EFI specd to get over 200hp over the original AMC 232 i6 's 100hp, but I'll believe it when I see it!
2. Dana 30 front end rebuilt w 4.56 gears upgraded from original 3.73
3. Dana 44 rear end rebuilt w 4.56 gears upgraded from original 3.73
4. 2bbl aluminum intake manifold '81-'86 #3237858 upgraded from original 1bbl cast iron intake manifold '72-'74 #3191690
5. New T-18 4spd Transmission upgraded from T-14 3spd Transmission , new bell housing
6. Jeep on lift and front and rear ends and suspension off. Currently grinding, rust treating, and coating the underside.
7. View of the underside. Not many rust holes to patch. Just a few small ones under the passenger storage box area.
CA Smog test and inspection requirements go by vehicle year. '76-'86 CJs have to have smog tests, but '44-'75 CJs do not. I got lucky with a '72. I've always wanted to have a CJ6 or CJ7 in addition to my heirloom '72 CJ5 so I'm definitely staying under that '76 mark if I do.
