33" vs 35" with 4" lift kit?? need help!!
Before I make a recommendation, what is you differential ratio? What is your intended use for your CJ? What wheel size do you have now and do you know the backspacing?
stock gears in a 85 will most likely be 2:73's, that AMC 258 i6 / 4.2l will be having a hard time pulling 33's. I see a gear change in your future.
So if I have 331 gears I can handle 33's no problem???stock gears in a 85 will most likely be 2:73's, that AMC 258 i6 / 4.2l will be having a hard time pulling 33's. I see a gear change in your future.
HOW SO ?I think you will be dissapointed.
A bit sluggish with the 33" tires. I have run 33's with a 3.54 ratio and they were OK but 31's are my preference on the road.HOW SO ?
I have run 33s with 3:55 gears rpms were around 4500 at 40mph dogging down hwy 4:11s would be choice
