351w and Ford T18 clutch assembly questions
- Featured
- 1
- VA
- '76 CJ5, 351w, Ford T18/D20, D44 (open), D30 (open), 2.5" BDS spring lift, 31x10.5x15 tires
All,
I'm in the early stages (still planning) of doing a 351w swap on my '76 CJ5 . I'll be using a Ford T-18 with a Dana 20 . I currently have a AMC 304 and T-18 w/Dana 20 .
Anyone out there do something similar?
I'm trying to figure out if I'm going to need a whole new clutch pedal assembly. Maybe if I'm lucky, I can find someone out there that has done this and fill me in on exactly what I need.
Engine, bellhousing, clutch components, and Transmission are native to a bunch of Fords, so it'll be easy to track down what I need between the engine and Transmission . Just trying to figure out if I need anything special between my foot and the clutch fork...or will I be able to use what I already have installed for the AMC 304 and T-18 .
Thank you!
Thank you!
