360 I.D. head casting #s
Buuushman
- Media
- 7
- Kihei, Hawaii
- 77' CJ-5, 360 c.i. motor, T-176 trans, D-300 transfer case w\ twin sticks, Dana 30 front, A.M.C. 20 rear w/ 4.10's, solid axles & trac-lok, 2.5" lift Y.J. springs.
Well, since it seems you have to have a removable eyeball to see the engine casting #'s on the back of the block, I pulled a valve cover off and got the casting # from the lifter valley- 3233344-1 between 5 & 7. It also seems to have A 79 cast in between 1 & 3. The V.I.N.s 6th digit is an H so it originally came with a AMC 304 and the more I read and talk to people the 360 was not a factory option in 77'. So What I have gathered so far is that I have a 79 360 with 58 cc chamber heads that made 160 H.P. stock at 8.25 to 1 compression ratio.
If anyone has access to any more info or can correct me on what I have so far it would be greatly appreciated.
Buuushman
Buuushman
