4.0 head swap questions
satxcj
- San Antonio Texas
- 84 CJ-7 258,TF999,TWIN STICK D300, DANA30 & AMC20
I'm currently trying to collect everything I need for my 4.0 head swap, so far I have the head ordered from odessa cylinder head should be home soon, I have the intake manifold with injectors, exhaust manifold, and wiring harness from an automatic 92 XJ. I need to order the Damper/CPS from hesco, air intake, and Transmission kick-down. The computer was already gone so I don't have that, my question is does it matter what computer I get (auto or manual)? If I have to get the auto can I just splice into the neutral safety switch from my original harness so it can start. Also if I use the E200 fuel pump do I need a pressure regulator? Lastly should I get the distributor and coil from an XJ or will I be fine running the OEM CJ distributor and ignition system?
