4.0 head thoughts
4.0 head thoughts
Rippin
Tavares, FL
1983 CJ-7, 4.2, T-5 & Dana 300, D30 and AMC 20
Ive been tossing around motor ideas lately, weighing price vs performance vs reliability, and i just keep coming back to a rebuilt AMC 258 i6 / 4.2l bottom end with an odessa head. Thats my best solution because i keep my T-5 and Dana 300 , its got better performance than stock, and its cheaper than buying and rebuilding a v8.
Now my questions. Ive searched and couldnt find clear answers to these. #1 Will my 4.2 intake manifold work? Ill be keeping the carb so f.i. isnt an issue. #2 will i need 4.0 lifters rods and rockers or will the 4.2 ones work? #3 head bolts. Ive seen it discussed before, but i couldnt find it. What size and length? Part #s would be fantastic
Thanks guys!
#1 mine would not fit. Some say they will. Go figure.
#2 push rods come in several lengths. If you deck the block and/ or the head that can also change things. Most important is to get the lifter preload correct. That is really what determines the length. AMC 258 i6 / 4.2l lifters are the same.
1983-96 4 CYL 2.5L
1974-90 6 CYL AMC 232 i6 or 258
1987-96 6 CYL 4.0L
1971-93 8 CYL AMC
#3. Also can vary. Check out this site.
Jeep 4.0 4.2 258 Cylinder head bolts / fasteners
Double think the FI. You will be amazed how easy it is swapping on a 4.0 head.
$35.00
  17.5%
