4.2 intake on a 4.0 head
tinman
- Idaho Falls
- 81 CJ7, I6, T5, D300, 4.2 block with a 4.0 head, Cherokee MPFI
Doing the conversion, I go to put my 81 intake on and it hits the #4 exhaust tube. Well, after doing some searching on here, it sounds like I need to do some "minor" modifications to it. I start grinding a little bit off of the bottom of the intake, then a little more, and before I know it I've made my way into the water jacket.
So, a couple of questions. First, should I weld the intake back up and "dent" the exhaust tube to make it fit? And second, should my '81 intake even fit? I thought the 2 barrel intakes would all fit with the 4.0 head.
Mine is a CA model if it makes a difference.
On a side note, before I pulled my stock engine out, I put it on the dyno to get the before numbers..... 88 hp and 166 torque. Does that sound about right?
