Trans 4 speed trans identifying
Jond417
Ross, OH, USA
77 CJ7
I have a CJ7 . I think I have a T-176 Transmission , given that the stick comes up at an angle and it’s a 4 speed with reverse down on the passenger side. It has a tag on the right side with the numbers
5359390
RHLK3
1142
Is this enough info to determine which Transmission I have?
:welcome:
5359390 = T-176 3.52 1st gear from 81 ~ 86 with a straight lever and an aluminum case (Link)-> Manual CJ Transmissions -< . 1977 stock 4 speed is a T-18 (Link)-> Manual CJ Transmissions -<
BUT, to be sure.
Do you have a VIN?
Have you looked at our database?
:welcome:
BUT, to be sure.
Do you have a VIN?
1977 vin plate but I think this thing was pieced together. It has a 360 in it. And I was able to finally read the left side of the case and it is 2604203.
Vin J7F93AA117877.
Thank you
Definitely not stock.
Back to my answer. Did you check the VIN? (Link)-> CJ VIN Decoder -<
Is the case aluminum or steel? 5359390 = T-176 3.52 1st gear from 81 ~ 86 with a straight lever and an aluminum case
My next issue with this is the bell housing. The socket for the ball bearing pivot is worn pretty bad. I am having difficulty locating the same bell housing to replace it. The part number on the one I have is 3233824. It has the 4.84" opening and a 3.5" x 3.5" opening for the clutch arm. I have located a bell housing with the correct opening size but the opening for the clutch arm is somewhat narrower. That part number is 3223278. Will it work with this set up?
It should work as long as it has the Ford bolt pattern (8.5" width top / 9.25" width bottom X 6.3") Because of the shift arm opening difference you will need the correct boot and you may have some starter flange interference that may need to be trimmed.
