73 CJ5 front disc brakes
gtocj5
roy, utah
67 GTO Post Coupe, 500hp restored, owned 25 years, 73 Jeep CJ-5 no rust survivor, 304, 4 speed, 33" tires, lots of mods. Just learning all about it.
I have a 73 CJ5 that has the front brakes converted to disc brakes. I am just thinking about when I need to change pads. What type of conversion could of been used so I can find the correct pads. Year and model etc info appreciated.
Pic's would help.
My first guess would be that they just up-graded to cj disc brakes.
The caliper bracket is either a 2 bolt (78 +) or 6 bolt (76-78).
:D
Pics would help for sure.
:D
Probably a stock parts type conversion. And measure the rotor thickness. Bracket type and rotor thickness should provide you all the info you need to pin down the CJ year you need to order pads against.
