Build Thread 74 CJ5 Build Nearly Complete BUT NEED YOUR HELP / ADVICE!!!!
joshuajackson8619
Alright so my previous car was a Chrysler Crossfire if that tells you anything I'm NOT mechanically minded but have always wanted an old CJ for years and years so I finally picked up this 74 CJ5 about three months ago and have so far put about $1,500 grand into it and it's come a LONG way.... Here's some pics and a list of what I've put into it / what it had when I got it as best I can think off the top of my head. Now what I need your help with is at the bottom in a numbered list - as I said I'm new to Jeep's and just not mechanically minded. I know what I like and what looks good to me and have others do it for me but I am out to save money so I do a lot of parts hunting myself and need to know what took look for / what I've already got, ya know? And I just have tons of other misc questions that I'm sure I'll add to as this thread grows. Thank you so much in advance for all of your help!!!
1974 CJ5
AMC 304 V8 rebuilt with 45,000 miles on it
3 speed manual
Fiberglass body
I've added new...
Amp
12 inch sub
4 marine speakers mounted to roll cage
Speaker in dash
Deck
Dash
Gauges
Indicators
Sky Jacker 4 inch soft riding lift
Bikini top
Brakes
Stainless steel brake lines
Control arms
Soft top
Soft doors
Locking safe
Corbeau seats with harnesses
Corbeau grab handles
Headlights
Grill
OEM turn signals
Diamond plate (black powder coated) rear wrap
LED taillights
Full roll cage
Replaced missing body mount on passenger side
Stainless steel door entry sills
Phone charging port
Dome light
Fuel pump
Steel plates bolted under the fiberglass body to reinforce it
Carpet kit
Spark plugs
New magnaflow exhaust
LOTS of engine work...............
Etc etc etccccccccccccccc lots more I can't think of right now.
Point being it rides, handles and runs a hundred percent better than when I got it. It originally rode like a dump truck and had a CJ7 lift on it incorrectly mounted and I was told by several mechanics they were surprised I was alive after driving this thing even a mile. It was terrifying - now it hits 75 mph on the freeway with no trouble and stays in one lane while doing it!!! And sounds GOOD.
To be done next:
Clutch rebuild (clutch is slipping a bit, not bad yet)
Throw out bearing? (Random light scuffing noises heard on occasion, mechanic say's that's what it is -doesn't occur too often.)
List of questions....
1. With this fiberglass body... I've got LOTS of cracks in the gel coat but it's otherwise a fairly good body aside from some ripples in the surface - looks like someone who didn't know what they were doing worked over the entire body and jacked it up. My question is what's everyones experience with the fiberglass body? I do like the idea of no rust and how light weight it is but is it possible to really have it worked over professionally and get all these cracks out and not have them all reappear like crazy??? Most I've talked to have said they'll always come back but I don't see Corvette's running around with cracks all over? Is it possible to rework this body to show condition and have it maintain it? Please note I'm NOT the off roading type really, I just want this mostly for looks and a daily driver if that helps understand what it will / won't be subjected to as far as stress on the body. What everyones experience in maintaining appearance on the fiberglass bodies??? Should I buy a steel body as my next step or would I be money ahead to just have the current body reworked??? Or money ahead selling the fiberglass body and putting on a steel body? My worry there is all the hours charged for swapping them out, etc.
3. Anyone ever seen pics of a CJ with a fiberglass body after being wrecked / rolled? How do they hold up? I worry about getting killed!!!
2. What year does this body look like? The reason I ask is NOTHING from an early CJ5 fits (like my soft doors!) and I've been told by some mechanics it looks like though this is a 74 that the body is a later model (76 or newer) CJ5 body or possibly a CJ7 - what is the differences between an early CJ5 and a late CJ7 in terms of measurements and also with the CJ7 ???
3. What is this windshield off of? I believe it's an early CJ5 windshield, but confused there as well.
4. I've been looking for an old fiberglass top to refurbish and have come across a few one especially i'm looking at is off a 77 CJ5 - will it fit this windshield and if not is it easy to swap my windshield and will it thus fit my Jeep or are the body measurements different (of course depending on what body mine even is)?
5. I've got a weird rattling sound when I put it in neutral at higher speeds (30, 40, 50 mph in 3rd gear) to coast to a stop - only when I'm at high speeds in neutral, sounds like it's coming from below the shifter and almost sounds like the rattle a diesel trucks lets out as it slows to a stop - any idea what it could be???
6. Is it possible to put an air conditioning system in these early CJ5 's? Are there aftermarket kits for it and how costly is it???
7. Thoughts on this engine? I know nothing about it and haven't pushed it too hard with the clutch issue, yet.
1974 CJ5
3 speed manual
Fiberglass body
I've added new...
Amp
12 inch sub
Speaker in dash
Deck
Dash
Gauges
Indicators
Bikini top
Brakes
Control arms
Soft top
Soft doors
Locking safe
Headlights
Grill
OEM turn signals
LED taillights
Full roll cage
Phone charging port
Dome light
Fuel pump
Carpet kit
Spark plugs
To be done next:
