75 CJ5 wont start.. Please Help
His post had it's last response over a year ago (notice it's April 2012, not 2013), and it seems that our problems are quite identical. Everything looks good, but the engine running is a no go.
Nightpath, I also think you should have started your own post, since the o.p. has a different ignition than yours. It will take some research the figure your issue out since you have spark and fuel. There is a known problem with those clip on coil connectors, which can either be replaced or a new coil installed with screw down connections. It could even be a hidden frayed wire somewhere. Sometimes jiggling wires around while it is idling can detect a bad wire.
I'll open my own thread. Thought I'd get yapped at with the typical "there's already 100 threads search and post in those".
Thanks to all of you for this info .. My son and I have been having this prob also, I will be calling him with this info .. our main prob is he lives 4 hours from where the jeep is, so this is going to be a long process in getting it up and running.:(
