79 CJ5 Build Getting Started
gadawg31
Admin, if I am in the wrong forum, please let me know and I apologize.
Getting everything ready to start my CJ5 build and wanted to ask some opinions/expertise, before I start spending money. Once I get the ole girl home, I will be pulling off the tub (fiberglass).
1. I want to do a disk brake swap on the front, not sure if I should do the rear or not. For those that have done this, where was your choice parts house and did you do the rear as well?
2. Also, I want to install a 4" lift while I have the tub off, any suggestions/recommendations where to get this kit? Right now it has only a spring lift and I was even told to cut my cost I could do an axle flip. I presume they meant putting the springs on top of the axles. Is this safe?
3. Finally, the soft-top I have chosen is the BestTop "supertop", comes with two soft 2-piece doors. Thanks in advance for the help and hope to gets some pics of her in a couple of weeks. Thanks.
JD
JD
