Build Thread 79 CJ7 build help
MudFlap
PGH
First Off - I am not trying to tell you what to do or which Jeep to buy.
Here is a list I made up ( replied to a post on another Jeep forum ) of
things you should do or ask regarding the Jeep you want to buy:
1.) Does owner of CJ have free and clear title to Jeep in hand. Ask to see
the title. Check for liens.
2.) Ask for any history on the CJ. Any prior owners you can call and ask
questions about the Jeep?
3.) Ask for maintenance records. Fluids changed regularly? Any new parts
installed recently?
4.) Take a friend with you who is knowledgeable and can give you an
objective opinion on the Jeep.
5.) Look the Jeep over from top to bottom - then do it again 4 or 5 more
times. Take your time. No rush here.
6.) Check the tires and all fluid levels if possible.
7.) Test Drive - How easy does the Jeep start, run, turn, steer, stop, etc.
Check 4WD ! ! !
8.) Check for any noises.
9.) Check all lights, horn, wipers, wiper washer, etc.
10.) Check the frame! - Check the frame! - Check the frame! - Any rust
through? Especially at the rear spring hangers.
Remember - There are other CJs out there for sale.
As far as mods such as lift, tires, lockers, etc. I would first concentrate on the
basics. Make sure the engine is good then check drivetrain components ( 4WD,
axles, Transfer Case and Transmission ) and brakes, steering, electrical, etc.
I recommend taking it slowly until you are certain the " basics " are in order.
Good Luck!
installed recently?
Check 4WD ! ! !
axles, transfer case and transmission ) and brakes, steering, electrical, etc.
Good Luck!
Thanks for the info. From what I am told its been garage kept since 97. Theres hardly no rust and it runs fine but we will go over everything once we get it back. Just trying to figure out what these jeeps like and dont like parts wise :confused:
:notworthy:
If your ging to run 35s Id get some 4 in. springs from either company you named and add Superlift into it. You'll need that body lift as well for 35s. Your gonna want to upgrade to 1 piece axles at the least in the rear AMC20 .
Thanks!
Am I gonna need a longer driveshaft and other things if I go with a 4"? What some better options rather than sticking with the AMC20 ?
I didnt need to change driveshafts on my 78. I had the 3 spd. Dana 20 behind a 360. What is it you dont like about the Dana 20 ?
Again I am clueless when it comes to jeeps, but from the info I've been reading, the AMC20 is weak? So if I buy the 1 piece axels they should be pretty tough for 35s for the average offroader? While we are one the topic of rear-ends, I'd like to get a locker as well, how are the OXs?
Gotcha I thought you were talking about your Transfer Case , thats a Dana 20 . 1 piece axles upgrade the AMC20 pretty good. The tubes are still a little thin and they are pressed into the center section.Throw a good weld around the tubes where they meet the centersection and you have a axle that can handle 35s. Just be careful not to warp the tubes.
The only lockers Ive been able to use myself are the lunchbox lockers. If I had the cash Id love to give the Ox a shot. The only bad thing Ive heard about them is that sometimes its a little difficult to adjust the cable correctly. Otherwise nothing but praise for them.
