Build Thread 79 CJ7 "They’re coming to take me away aha"
You both added some very useful upgrades this winter/spring that will serve you well. Well done!
I believe that U joint came from Tom Woods. I had to use one when I first built my rig until it settled down.
Sent from my LG-LS777 using Tapatalk
Good eye. That's exactly where it came from. Apparently, there are Toyota joints that will do the same thing, but are very prone to breaking. From what I have read, this is more or less the same joint on steroids. As a matter of fact, Tom Woods guarantee states that if the joint fails and damages your driveshaft, they will replace the driveshaft.
I would have preferred cutting the knuckles loose, rotating them and rewelding them to get correct geometry for everything, but time is running short before we head to Moab this year.
I don't blame you for cutting a corner to get ready. I ran that U joint for a couple of years and even though they said it would vibrate, I never noticed it over the rest of the vibrations in my rig.
Ya, I'm thinking maybe next year doing it the right way, and cutting the knuckles loose and rotating them so I can go back to a regular U joint. The inner seal has developed a small leak, but if I have to take things apart that far to replace the seal, the wife and I agree, chromoly axles, and rotating the knuckles. Do it all at once. That way the front is ready to accept 35" tires if that's the route we choose to go when the 33's wear out.
$150.00
  75.0%
