82 CJ5 distributor advance
cityjack
Hey all,
I have basically stripped everything emissions related off of my AMC 258 i6 / 4.2l . I have the PCV hooked up to the large port under my BBD carb. I have a max vacuum from under the carb going to the vacuum advance on my distributor. Can anyone tell me if I should be hooked to a particular different port for vacuum advance? Also I am not too sure if my vacuum advance is even working to be honest. It is an electronic ignition distributor from Motorcraft. Can I purchase the vacuum advance from somewhere instead of the whole distributor if the advance is not functioning? Is there another better setup for distributor and carb other than the BBD and the Motorcraft? Not that they are bad just am open to other ideas. My throttle shaft is somewhat loose on my carb and does make my idle speed change but other than that it idles pretty good.
Thanks guys
Sid
Thanks guys
Sid
