82 Engine mount compatible with an 84 CJ7?
CJHoss
Choctaw, OK
1984 CJ7 Laredo with 4.2L 258 AMC 6 cylinder engine and factory rear locker. Awaiting restoration.
2001 XJ Limited with Zone 4 inch suspension, custom air intake, Terraflex track bar, full size spare, etc etc...
Hey yall lookin at gettin a new AMC 258 i6 / 4.2l I found in the yard. Boss man says its from an 82 and thinks that it won't work with an 84 CJ7 , which is what I needs the engine (it used to have a AMC 258 i6 / 4.2l in it as well).
But I recall not much of a difference till you hit the later years.
So the question, will a AMC 258 i6 / 4.2l engine from 1982 drop into a 1984 Jeep CJ7 with the same mounts being used. Are the two compatible with each other?
Yes they are the same.
