Build Thread 84 CJ7 coming full circle
I dont care for those flat ones at all. Id take the pocket style over and over and...![]()
Thanks for the opinions, y'all.I agree "Pockets" !!![]()
out of the motor.
Thanks for reading.
*sigh*
Is God trying to tell me something?
I start get going again with cutting off old brackets from my frame...Getting rid of more of the "what was I thinking" stuff from years ago. I've also learned a valuable lesson for others to take heed to -- When you're building your suspension for the first time, AND you're learning how to weld...don't do these two at the same time. I THOUGHT I was doing "ok" at the time...Now that I'm a certified welder, I'm looking at these welds, and shaking my head in shame. I'd cut into them with my grinder, not cutting too much into them...Definitely not getting into either the frame, or much into the brackets...and smack them a few times with a hammer, and they'd bust right off.
Anyway, all my old brackets are removed from the frame. I ground what weld was left smooth. I didn't take any pictures, well, because I figured we all know what a smooth, stock CJ7 frame looks like. As soon as I started cutting steel to make some new suspension brackets, my grinder gave up on me... Took it apart, and the pinion gear in the head had stripped all the teeth off. I guess that would explain the slight "rattle" noise I'd heard from it as of late. Oh well, it was a Harbor Freight special, and it's lasted for over 4 years. I guess I got my $20 worth out of it. So no more work for the Jeep right now, until I get another grinder.
So I go to run some errands...A/C in my truck is blowing not-so-cold, almost warm air. Hmmm.... when I get home, upon further investigation, I find it odd that the compressor is cycling on and off every 8-10 seconds. Then I see that the condenser fan is not on at all while the compressor is running. Hmmm....I just got frustrated, closed the hood, and came inside to enjoy a cold one over yet another day of next to no progress. There will always be tomorrow.
Your just gonna have these days. Happens to everyone. Hang in there , take a step back and enjoy your nite.![]()
But apparently I started griping a little too soon last night...
:jeeplove:Hey I'm working on my welding cert too. I work for a contractor we do work for the navy.
Now I REALLY have to get my pics uploaded so I can broadcast it to the interweb.![]()
All I see is this.![]()
I'll see if I can get my lazy bum up early tomorrow and post up some pics.
I'm one of those night crawlers that does the 3-11 thing and doesn't get to sleep until near sunrise.
that I've got stacked up in the back, too. I wouldn't mind if it were about an inch lower, but now I guess I'm splitting hairs. My other point here is PA's tire coverage laws. Knowing what I know what they "say" about tire coverage and flare width, I don't know if I would get in trouble for 7" wide flares. On the flip side of the coin, the JK's come factory with flares that are probably in the range of 8+ inches on the front.
What say the people of Jeep CJ?
That just looks sweet right there:
Most things I do on my Cj are under a strict budget , but I havent gotten to the point your at with your axles. I think its something you only want to do once. If your already saying you dont like wide flares you wont be happy. Im not a wide flare guy either. I did stock Tj flares on my last Cj and Im not even sure I can handle the squareness of them this time around. Heres a comparison on my old CJ7 . It opens the wheel wells nice but...
