Build Thread 85 CJ7 Rebuild, Labor of Love
Please forgive my lack of knowledge but what is “welding the tubes” and what benefits does it give.
No worries at all, if you’re referring to my update regarding the AMC20 rear axle, the axle tubes are just pressed into the differential housing (normally). When I rebuilt mine I welded the tubes to the housing for stronger contact. It eliminates the possibility of breaking the axle under large stresses (e.g. off-roading) due to the tubes pulling away or spinning in the housing.
You can go a step further and weld a truss across the diff housing to further reinforce each side, depends on what you want to do with the Jeep.
I was rebuilding the axle, so I went ahead and did it as it gains a lot with little effort relative to all the other work.
No worries at all, if you’re referring to my update regarding the AMC 20 rear axle, the axle tubes are just pressed into the differential housing (normally). When I rebuilt mine I welded the tubes to the housing for stronger contact. It eliminates the possibility of breaking the axle under large stresses (e.g. off-roading) due to the tubes pulling away or spinning in the housing.
What kind a welder did you use. I have access to a 110 amp welder mig welder. My AMC20 is out right now and I will be rebuilding it. Seems like a no brained to weld the tubes.
What kind a welder did you use. I have access to a 110 amp welder mig welder. My amc 20 is out right now and I will be rebuilding it. Seems like a no brained to weld the tubes.
I also had a local shop do mine. It cost me about $50 to bring it to the shop after everything was disassembled. They skip weld it since The tube tends to pull in the direction of the weld slightly therefore they tack one side then the opposite to counter act the pulling before going all the way around versus taking the bead all the way around from the get-go. It took the guy an afternoon.
If you can weld I’m sure you can handle it.
Doesn't look that bad to me. My concern would be what was it hitting and why.
Thanks. Yeah, my thoughts too until I opened the box. It was a mess in there. Pieces of the heater core piping were laying in the bottom which would explain why my heater never worked. And I’m pretty sure mice were living in the fan wheel.
Ok, looks seriously sweet, but what model is it? And I’m jealous as I’ll be holding my breath that mine holds together.
Haha. Thanks. It’s an AX15 from Novak. It also has the adapter plate to mate it to my Dana 300 . I rebuilt my T-5 and then sold it after I decided to go all in on the 350 sbc. I’ve heard great things about this 5 speed.
They sent me a straight shifter with it, ready to bend to my preference.
Haha. Thanks. It’s an AX15 from Novak. It also has the adapter plate to mate it to my Dana 300. I rebuilt my T5 and then sold it after I decided to go all in on the 350 sbc. I’ve heard great things about this 5 speed.
Been thinking I wished I had gone this route. Going from a T-4 to buying a used T-176 and rebuilding it and replacing some gears and other parts I am probably approaching the cost of a good used one. Oh well next time
I almost went the same route. After rebuilding my T-5 it wasn’t too bad, but I don’t ever need to do that again.
SWEET! My build thread is back up. Stand by for some updates coming. Lots of progress.
Nice! I like the look of the new bolts! I painted mine after tightening everything, kind of double questioning now.
I’m also wondering if I should’ve went with a lower ratio than 3.73. It’ll be interesting to see how they compare.
My reasoning for the 4.10 ratio was what I’ve looked up for the tires I want to run. It was the optimal ratio.
