    Thank you for your support!
Build Thread A 1984 Black CJ7 Build - My never ending project/addiction
They are Delta Flow 40s.
https://www.holley.com/products/exhaust/mufflers/street_chambered_mufflers/40_series_delta_flow/
I dig the sound. It's not excessively loud.
Do you have any scrubbing in the front when you turn? Just got my lift and tires on and have a little scrubbing on passenger leaf spring when I turn left.
Not at all, even during very tight turns. Does your jeep have wide track axles? Maybe that has something to do with it. I have factory 15x8 wheels, so my offset really isn't very aggressive.
You are really passionate about car modification. Good job keeping this thread up to date.
Thank you. I have a few mods coming up soon. I just had to install a new alternator, but my new skid plate for the 21 gallon tank is on back order. As soon as it comes in, I will be removing the rusty old one and putting the new one on. The dana 60 rubs slightly on the factory skid plate, so hoping to mod it a little for clearance.
Its definitely not quiet, but its not crazy loud either. A very muscular sound, but not nearly as loud as standard 40s. I have headers and no cats, so there isn't much restriction.
I was able to adjust the bolt on the hub so it doesnt scrub. Doesn't have the turn radius it use to but I dont care and fine with it. Finally got the pipes put on today and pretty happy with the sound. I think i need to re-gear it because I can only do about 50mph max in 4th gear.
What do you have for gearing? I have a T-176 , with 4.10 gears and 35s. I have no prob going 60, but it does rev a bit at that speed. I have plenty left, but it’s not comfortable with the revs and loud 360.
I think i have the 3.55 gears with the T-18 4 speed. 1st gear is Granny, 2nd gear almost pointless to use, so that leaves me 3rd and 4th. I get really high RPMs at 40mph and higher. It feels like it definitely needs a 5th gear.
I really can’t comment on the T-18 you have as I’ve never owned a Jeep with that Transmission . But, my friends both have the granny gear T-18 and it’s def not designed for cruising at 50 mph. It’s basically a 3 speed. I love my 176, but even I’d like a AX15 or something with a 5th highway gear. It’s fine around 50-55, but anything more is just not fun. I’d never want to bring it on the highway. Plenty of power, just not a great idea due to revs.
The AX15 may be on my list to get. I dont need to go faster than 60mph and dont plan to have on the interstate but i would like to cruise at 50-60 mph with out hitting high RPMS.
