A bumper question for fabricators, builders or installers
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
I bought my CJ with a terribly under strength PO designed bumper. He essentially removed the rear cross member and installed a 2"x4"x1/8" tube. It looked good on the outside but was a mess in places you can't see. So, today I removed it and was happy to find the rear of the frame unmolested.
So, here is my question. Originally it was my intention to use a remanufactured rear cross member to return the frame to it's original configuration. Then building a complete heavy duty bumper and attach it to the stock configuration cross member. Not a bad idea if you can ignore the fat that the cross member isn't very strong. The thought that I could build up the cross member with a /-1/4" plate hidden in the channel behind or hidden from sight. That would make a super strong cross member.
Then I got to thinking. Wouldn't that be similar to building two bumpers? Would it be better to just build my bumper to attach to the back of the frame with extensions designed to attach to the inside of the CJ frame.
So, builders, how would you or how have you attacked this sort of problem. Make one strong bumper or make a strong, stock looking cross member and attaching a strong bumper to that?
