About to do a brake overhaul
hopefulcj
- north florida
- 1980 CJ7-258 I6, MC 2100 carb, team rush upgrade, T4, D300 tcase, D30 w/aussie locker in the front, AMC20 open, I think PO put 4.88s in the diffs, 35,000-135,000 miles, you pick. 4"susp lift, 2" shackle, 35" <-BAD WORD-> cepek AT's on black steel wheels, 1 1/4" spydertrak wheel spacers, most everything else i believe is stock, finding things out as I go
Like I said, it's time do a break overhaul on my 1980 CJ7 with a stock Dana 30 and AMC20 . How do I figure out if I need 2 or 6 bolt pads? How thick are the disks? I am pretty sure sure that the rear drums are 11 inches but can anyone confirm this. Last question, my E brake cable ends at the "split" underneath the drivers seat. The I bought the cables I needed to hook up the cables to the drums but I can't figure out where they connect to, and or if I'm missing any brackets, and could anyone post a pic of an E. Break set up?
Thanks you in advance. I've never done brakes before but the jeep should be fairly easy.
