Engine Accidentally pulled lifter, can’t get it back in
Brently2003
So I was changing my valve cover gasket, noticed in the rear it was missing a bolt.  Saw that the front most bolt was same size as it, dug in my box of random bolts and found one for it.
I wanted to make sure it was right so I screwed it into the front hole to verify and after unscrewing it my fat fingers dropped it and plop right down in the rod hole. Got my magnet out and went fishing. After numerous failed attempts I concluded it must have been stainless and non magnetic, but the lifter is and accidentally pulled it out of the seat.
I got a claw tool and successfully retrieved the bolt without dropping it further into the engine and have been playing all day with the magnet trying to reseat the lifter. I can get it upright and looks to be over the hole but just can’t get it to drop in.
I got the performance tool valve lifter tool, but the “skirt” is just a bit too big to go thru the rocker hole, and if I file it down it would lose the ability to work as the tool.
Does anyone have any ideas? Trying to get it in without having to pull the head, it’s so close, just not quite.
Thanks,
Riley
Thanks,
Riley
