AMC 360 Headers CJ7
AMC 360 Headers CJ7
MarkCJ7UK
United Kingdom
Hi Guys , Brand new here and straight away askin questions , (sorry),
Recently picked up a CJ7 with AMC 360 , the car came with 2 sets of headers 1 set fitted and 1 set spare,
I believe 1 set are Headman headers ??? unsure,
The set fitted and running now fit inside between the chassis rails and cylinder block, these touch ( just brushing ) the inside edge of the chassis rails on one side is this normal ?
The second set look like they will run outside the chassis rails , so if fit these I guess I will need side pipes (not ideal off road ) advice or comments more than welcome ,
Welcome, your likely correct they are headman brand. I think they are the only ones that make inside the frame rail headers for theV8. Can't tell you about rubbing as I have the headers and I'm in the middle of a rebuild with a 360. Good luck.
Welcome aboard from Texas :chug: rubbing is racing lol take a hammer and "massage" the offending tube this is common with all cars and headers nothing to it :chug:
