Anti Theft
JeffP
- Media
- 28
- Peoria, AZ
- '75 CJ5, 304, T18, D20, D44s w/3.73 1974 CJ5, 304, 4 spd., Dana axles 3.73 gears. 1973 CJ5, 258 I6, T18, Dana 20, Dana axles 4.27 gears. 1972 CJ5, 304, 4 Spd, Dana 20, 4.27 gears. 1976 CJ5, 304, T150. 1976 CJ5, 304, T150, J20 w/4.10 gears. 69 CJ5 Hurricane 4 cyl, 4spd all original! ‘53/‘54 M38a1 100% original but also 100% apart! Low 3 digit Vin! One of the very first m38a1s!
I use the floor mounted dimmer switch to cut off fuel and make the fuel gauge read empty. It will start & run, but not for long.
This would be excellent in a car jacking situation... as you exit, tap the switch with your foot. After it quits he will realize it just ran out of gas & start running. Simply walk half a block & get your Jeep back.
