Axle c clip installation on Dana 30
- Media
- 10
- West Springfield, MA
- 1986 CJ7, SBC 350, Dana 300, D30, AMC20
Rebuilding my front end and passenger side went together smooth as silk. Driver side, I cannot pry the axle shaft out far enough to get the C clip groove fully exposed. It's new spindles, rotors, bearings, and locking hubs. I know the two wheel bearings are different size, but you cannot screw up because the rotor will not slide onto the spindle if you have the bearings backwards. I torqued the two axle nuts two 50lbs which is correct and I don't think I want to go any further as that side already feels a little more preloaded then the passenger side. Any ideas?
