Backfire
Hi, I have a CJ7 1984 with a AMC 258 i6 / 4.2l totally rebuild. I installed a new MC 2100 1.08 but in low is making backfire. The timing is setting at 8.
Backfire in a carbureted engine usually is a timing or lean mixture, as the timing is not advanced to much I would think you have a lean condition. Maybe a dirty fuel filter, air filter or maybe a weak fuel pump or a carb kit.
have you tried changing the mixture. i have my motorcraft at 2 turns out on both screws. it dont like any more or any less than that.
Thanks for the help but the fuel filter, carb and fuel pump are new.
A vacuum leak on the intake manifold can also cause a lean condition there bye backfire.;)
